Hi ddickey,
unfortunately, the gib has been slightly bent and is creating resistance.
fortunately, the gib can be removed and straightened.
if you have a surface plate, it would be easy to see the bend.
otherwise you'll need to lay it on some thick glass or a mill table or otherwise flat reference
you could then sweep the gib with an indicator, to ascertain the bend height
then straddle the gib on parallels, with the parallels about 1/4 the distance from the end of the gib
now you can press the gib back into shape either manually or by hydraulic means.
if the bend is small you may be able to use a block of wood as a tool to depress the gib, or your hand may work too
if the bend is larger or sharper, hydraulic means may be necessary.
with either method you'll need to compensate for deflection.
my rule of thumb is 1.5 of the error.
so lets say the gib is bent .004",
you'll depress the straddled gib .006" and then re-check the error
rinse and repeat until the gib is flat
another rabbit hole would be to run the compound surfaces across a blued up surface plate, but then scraping would soon follow
