Cunliffe Horizontal Milling Machine
Brain Coral
Jul 26, 2013
584
Hi there... :)
Anyone have any experience with these mills ?
Here's a pic of the mill....
Brian
Hello Millbo,
I attempted to reply to you, but my post went AWOL for some reason.... Yes, this mill is brutally heavy... I ended up buying it yesterday and got it into my shop today. Here are some pics of the mill on the trailer...
Here are some pics of the dividing head, change gears and factory assembly for spiral milling, etc. ...
Cheers.... :)
Brian
Here's a few pics of the dividing head on the mill, along with the outboard gearing assembly in place. I just played at it until I completed a gear train, but I don't know anything about it. I have ordered a manual for it from Tony Lathes UK. Lots of work up ahead to clean this mill up.
Brian
Very cool. You are going to be able to make some very fun stuff on that machine. Great find.:greenwithenvy:
I found out today, that this mill is a "universal" mill, in that, the table can swivel up to 50* from horizontal.
Here are a few pics...
Brian
Hello all,
It's been about 4 months since I got back to the mill... been a busy and eventful 4 months....
So last week, I decided to take the ram off and clean up the ways; as the lubrication of choice in it's former life has been grease... :yikes:
It was difficult to get close enough to the machine to get the slings centered, so I helped it along with some ratchet straps...
The ram is a hollow casting... still no slouch for weight, but it made it much easier to flip the ram over to clean it up. It must be at least a couple hundred pounds, but not much more...
Planer marks are clearly visible on the non-contact areas and just a hint of scraping left on the bearing surfaces...
A dark blue colour is showing on the underside of the ram. This may have been the original colour. I like the present colour of green, but it is clearly a re-paint.
Once the ram was cleaned up, I then went on to the top of the column. I decided to remove the ram clamping bolts as well as the clamps to do a proper clean-up. Unbeknownst to me, the clamps are housed in a through hole, not a bottomed hole and I heard the sickening clatter of the first clamp falling into the bowels of the machine as I removed the first bolt... :panic:
I took a look down the hole with a flashlight and could see that there was an oil return channel in the column casting where the clamp had likely gone down in. So I took the cam panel off the side of the machine, which gave me access to the main gearing and shafts. Shining the flashlight into that maze of shafts and gears as well as squirming my hand blindly into the confines yeilded nothing. Now I'm beginning to fear that I might have to pull all of the shafts and gear clusters to get at this part... so I sat down on a stool to think about it...
I was looking at the side of the mill where the clamp was when I suddenly realized that the oil sump and cleaner was immediately below and 4 feet down the area where it had fallen. What are the chances that it went down there ?:bitingnails:
Wow... !!! Was I ever lucky... There it was, so I gingerly put a strong magnet on it and had just enough clearance to get it through between the casting and gear...
Here's the part...
And here's the oil sump opening...
I had planned on removing the sump cover anyway, so I cleaned it up as well as the oil "filtricator" ...
All went back together and I was VERY thankful for my good fortune... :)
Cheers... :)
Brian
you got yourself a fine machine!!!!
i'm very jealous....:jester:
Well, don't be jealous just yet.... it was purchased without power to test it, so I may have bought a boat anchor and am investing a great deal of time before I get it into place. I still have to wire in a 10hp RPC to fire it up and move machinery around to get the mill in the position that will make sense.
Here's hoping... :)
Brian
Well, before you go throwing it in the water, let me know.
i'd be tempted to go up to New Brunswick and fish it out of the drink!!!!
wiring in the RPC is the fun part, at least for me.
should you need any help figuring things out, i'd be happy to assist you in any way i can.
it looks like you aren't afraid to get down and dirty,
so i'll be very interested in seeing how this comes along.
good luck.
