Cutting/Drilling a Caliper
rwm
Robert
Mar 25, 2013
4,614
I am think about using a caliper as a DRO for my drill press:
I am working on a mounting scheme. Is there any problem with cutting off either end of the caliper? I was thinking about cutting off the end with the two small holes and drilling a single mounting hole centered to the beam. I know these are capacitive but I am not sure exactly how they work and what would damage them? Who has experience with this?
Robert
I've seen guys drill a hole in each jaw, then place the holes on a pin or screw them down. This works well for a lathe tailstock.
I did something similar, using 4” digital caliper from HF, I made a dro for my tailstock on my lathe. No problems with it working afterward, just had a hard time drilling through it.
The depth rod is in the center so a center hole is out, may need carbide drills , don’t think ied cut the end off.
Thanks for the replies. The depth rod has already been removed. This stuff is not that hard; I have drilled one before but on the opposite end. Any one know about cutting the end off?
Robert
Robert
I haven't tried it, but I've read about people cutting the iGauging style capacitive scales without issues.
You should easily be able to cut parts off, use an abrasive cutoff wheel, I did so with a couple of defunct dial calipers, used the remains to measure through holes and internal recesses ( I locked the measurements in place, then measured them with another caliper or mike.)
  • Like
Reactions: TTD
Robert
Here is the advanced version... ;)
Yes that eBay caliper would have worked but I like the larger display on the Titan.
Also, this particular caliper was really hard, not just Chinese hard. The last one I cut was not so hard. I will be drilling a hole in one end of the scale with carbide. I hope that will not damage the functionality.
Robert
