I had occasion last week to make an aluminum pulley for a project I was doing. The pulley was easy. The keyway was not. I am not interested in paying a couple hundred bucks for a broach set that I will only use once or twice in my lifetime.(plus the arbor press that I don;t have) I had read an article about chucking up the pulley in the lathe chuck, making a cutting tool (like for a shaper) and running the carriage back an forth to cut the pulley. It sounded good. Very quickly reality set in and I came to the conclusion that whomever had written the article I read about this concept was either lying about it or I entirely missed how he was doing it. I spent about 3 hours messing around with it. I ground cutter to go into a boring bar. After about 500 (at least is seemed like 500) passes back and forth with the cutter, I had a keyway about 25 thou deep. Perhaps the broach set is priced the way they are for a reason. Has anyone done this type of keyway cutting? Can anyone tell me how they cut keyways without a broach?
