In absence of a manual, I made some assumptions regarding the change gears and lead screw. I assume that the h in the charts indicates a spacer so the gear on the same shaft functions only as an idler. It also appears that the lead screw is metric and the pitch is 2 mm. Going through calculations for various thread [pitches based on the charts, it appears that only the .5mm, 1.0mm, and 2.0mm pitches are exact. The others are, IMO, poor approximations of the nominal pitch. It gets even worse for the SAE threads. It is theoretically possible to select gear combinations using additional gears to create close approximations to nominal pitches although it may be hindered by physical restraints.
In other concerns, pluses for the lathe is the large bore size, a 1.5 hp. variable speed motor, and the long bed length. On the negative side, the low wt. means loss of rigidity which is one of the biggest drawbacks to a small lathe. The ways are flat as opposed the having a vee way for more positive positioning of the carriage and tailstock. There is no mention of the chuck mounting scheme. I suspect that it is threaded. If so, what are the threads. This is important when one desires add a four jaw chuck or a collet chuck. A faceplate is not included. Only six change gears are shown in the included parts while the charts show 10 gears, meaning that quite possibly all of the threads shown cannot be cut with the stock gears provided. Curiously, the marketing hype states that the 3 jaw chuck can mount bith round and square stock. I am at a loss as to how square stock can be mounted in a 3 jaw chuck. (Joe Pyczinski shows a work around but not an easy method)
Based on these observations, I would strongly recommend not purchasing this lathe.
