- Jan 22, 2011
- 8,031
Scissors
No, though I have been over once in the past and another life. I didn't realise you were in WA until now.Mayhem link=topic=2112.msg13782#msg13782 date=1305113733 said:Bollie7 - not heading over to Perth any time soon are you? I'll put on a BBQ and beer ;D To be honest, I wouldn't even know where to begin scraping a bearing and would more than likely end up wrecking it. As you said, it has obviously been working previously with the current shim set up and I can vouch for this given the amount of chips (swarf to you and I) that I dug out of her when cleaning her up. Everything I have found out to date points to a build date of between 1895 and 1905, so this may have been state of the art in bearings back then Going as thick as possible with the shims to reduce the overall number is the plan, as is to have equal thicknesses on each side.
