CX706 10x22 lathe noise. Is this normal?
I have the CX706 as well. Mine makes more noise the same as yours in reverse. I set the gear clearances up wit a piece of paper. How did you set yours up to be better? I noticed it was a lot louder when I changed gears over to thread a 13 tpi. I normally had it set up to achieve the best finish before I switched it over for threading the other day.
