I have a PM-30MV which is similar size and a friend gave me a 8" Yuasa rotary table that he had laying around. Just before that I had purchased a Vevor 6" online and was waiting for it to come in. The 8" is much heavier, and does fit the table though it looks too large and I could see issues with table travel looming. I was also a little worried about wear on the ways of the table due to the weight.
I got the 6" and mounted it and played around with it too and it is a much better fit for my mill, plus it has the option for horizontal or vertical mounting that the Yuasa lacks. I am pretty happy with the 6" and will probably use it the most. True, the Yuasa feels smoother and tighter and better built, but if i didn't have the two to compare I would not know the difference.
I will keep the 8" around for holding bigger things in case i have the need, but the 6" is much better suited to my mill and will get used first every time if material fits it.
The local supply house I buy machine tools from has commented in the past when i compare the top of the line equipment to the stuff I can afford, "it is more accurate than you at your experience level, and if you use it enough to be bothered by it's shortcomings you will be ready to step up to the good stuff." I got that advice when shopping for a vice and comparing the Kurt to a well recommended import he had on hand for much less. I have to say he was very right as I am still not ready to upgrade my vise, though when I do, if I do, I will be a smarter shopper and know more what I want.
