Determining the Chuck Taper: Jia Piin JP-30 "Drilling & Milling Machine"
mattgray_calif
Aug 27, 2021
5
Hello everyone, Matt in California, just getting started and looking for some additional guidance.
Picked up my first drilling and milling machine. But getting started has been quite the challenge.
Someone once told me "If it isn't on Google, then it probably doesn't exist." Well, this particular Jia Piin JP-30 isn't on Google, and it didn't come with a chuck.
Best as I can tell it seems to accept a MT2 spindle, with a Gage Line Diameter of 0.7370". While I did not scope it to see if it would accept tang, the total depth appears to be 3.550". I understand a true MT2 should have Gage Line of 0.700" and 2-15/16" depth.
Does anyone have addition information on this machine, or can point me in the right direction? I reached out to Jia Pin (hoping they are the same as Jia Piin), but so far no answer.
Thank you,
Matt
sorry didn't see mill/drill-
a drawbar would be best for milling
Being a mill/drill shouldn't it have a draw bar?
It has a drawbar, and I'm embarrassed to say I didn't do a close enough inspection. I removed a R8 3/4 collet a few moments ago. So at the risk of asking a dumb question, would I remove that collet to install the R8 chuck assembly, and just use that collet when installing bits?
Matt, your mill has all of the signs of being a Rong-fu. The model 30 was the older type, and had the thinner column. From what I've seen, this was the model to have the most variations, even though they are subtle. The 3-bolt clamp is different, but the rest of the head casting has the rong-fu curves and component placement. Knowing what your base machine is will help you find parts and get help on this site. You should be able to do lots of good work with this machine, once you've cleaned it up and dialed in your adjustments.
It is very good news for you that you have an R-8 spindle. It is the most common, so there are lots of tools available for reasonable prices. It shouldn't take much to get started with the basics, and there is a lot of used tooling that will work with this mill. So congratulations and welcome!
