Hi. I bought one of those ubiquitous dial indicator bases that look like the cheap Harbor Freight ones. It was inexpensive at a garage sale, so even though I usually avoid this stuff, I bought this one. It only lasted me a few uses before the knob became too hard to turn. This tool is not that old, but it seemed to be jammed tight. I saw a post around somewhere, but I cannot find it now, that said unscrew the center post and the hole will go all the way down to the magnet, and a small amount of oil can be dribbled in. This should free up the rotating magnet. I tried this, and it did not work. The magnet was as as tight as ever. It is tight enough so I am in danger of dislocating a finger if I try too hard to turn it. I peeled off that cheapo thin aluminum front, revealing a couple of screws. Removing the two screws allows removal of a bezel that holds the knob in. When the knob is removed, the innards are revealed. It is composed of a cylindrical core that is magnetized cross wise. The two pole pieces have rounded ends which turn in the circular bore, and are separated by a brass plate in the middle. Apparently, they have come loose from the brass plate and can become cocked, jamming them in the bore. The solution is obvious: extract the magnets, separate them from the central brass plate, and glue the assembly together so it doesn't bind. This thing is just so cheap and unreliable, and I regret even paying a couple of bucks for it. NOT SO FAST!!!! If you extract the magnets and separate them from the case, the risk is run of breaking the magnetic path and losing their magnetism. Many stories of woe appear on the Internet. Since the pieces are loose, special care must be taken not to allow them to become magnetically separated. So, has anybody had any luck fixing these things? There are two ideas that I have, but both of them are not real fixes. First, I can dial the base to the "on" setting and use it as a permanently on magnetic base. I can even duct tape the hole shut. The second way is to machine an aluminum knob and connect a huge handle which I can chuck an adjustable wrench or a big cheater bar to actuate the indicator. This is difficult, and may cause disturbance to fiddly set-ups. I have a Starrett base, which is obviously much older, and it is as smooth as butter. It feels high quality and impossible to jam. Still, I hate to throw things away if they can be fixed. Is there a clever fix like "tap from both sides simultaneously with a copper hammer" or some other silly thing to get this thing working again? Maybe they just aren't meant to be used.
