- Aug 3, 2017
- 2,437
So, I was browsing the internet the other day, and found this: https://www.amazon.com/gp/product/B07F243HLG/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
It claimed 3 phase output from 1 phase without all the VFD business. I personally am a huge proponent of VFDs, I've owned 5 of them (typically the chinesium ones) and liked them for what they are.
However, one of mine is(spoilers, was) on my surface grinder. The surface grinder has 3 different motors, two that power up together, and 1 that does not. The two that power up together are Spindle + hydro pump, then a coolant pump powered up later.
It also has a pretty complicated electric panel of its own (including an outgoing 220v 1 phase plug for the coolant pump AND a 110v 1phase plug for something else), so I opted originally to wire the (greatly oversized) VFD in 'after' the switch and leave it always-on. I ended up programming it to recover-on-fault, so that when I pressed the power button (which is on the 'wrong' side of the VFD, wired exactly as they tell you not to!) I would have to hold it to allow the VFD to 'fault' and recover and turn the 2 main motors on.
After that, everything seemingly worked acceptably. However, I did discover 1 annoying issue, the spindle motor didn't 'recover' well under resistence. I would take what should be a perfectly reasonable cut, and the spindle would slow/stop! I presumed that this was because the VFD didn't properly respond quickly enough to the increased amp load due to the other motor.
Thus, I opted to see if this "Digital Phase Shifter" would be any better.
I got it in the mail yesterday, and it seems to function alright! It starts up perfectly on the first press of the power button, and the spindle spins at the correct RPM still.
I did a somewhat 'heavy' test cut, and it slowed a little but didn't stop! I consider it a success.
Now, these things seem pretty expensive (more so than the VFD!), but for someone who doesn't want to deal with a VFD and already has an electrical panel/wire-up they'd like to still use, these are perhaps just the ticket! They are very simply: 220v 1 phase (2 wires) IN, 220v 3 phase (3 wires) out!
