Dividing Head for PM-25 Mill
addertooth
H-M Lifetime Diamond Member
Jul 31, 2020
737
I would use one to cut precisions flats on round stock at precise angles, or to cut gears. Perhaps even a precision slotted tachometer wheel.
devils4ever
H-M Supporter - Gold Member
May 13, 2019
840
I've been using hex and square collet blocks, but sometimes you need to divide by other than 4, 6, 8, 12. Right now I'm making a tailstock tap/die holder that is 2" in diameter. I want to flute it for grip since my knurling tool is too small. Planning on 36 flutes around the circumference.
I do plan on cutting some gears in the future although I'm not how possible that is on a PM25 mill.
Winegrower
H-M Platinum Supporter
Jul 29, 2014
1,934
I bought the cheapest BS-0 on eBay. It’s impressively great. No sand, beautiful ground surfaces, smooth operation, etc. It was in the $240 region. Fully satisfactory.
devils4ever
May 13, 2019
840
Now, I've got a problem. I tried to remove the 3 Phillips head screws hold on the indexing plate and one was so tight I rounded out the head.
I was extremely careful doing this knowing these were tight and the put my full body weight on it and it still rounded out.
I'm not sure what to do!
devils4ever
May 13, 2019
840
Well, I talked to Precision Matthews and they suggested drilling it out. I used a large right angle plate to mount it to my mill. Then, I used a gage pin to center the mill over the hole. I started with a large center drill. I quickly realized that I could mill off the head to remove the index plate and gain access to whatever is sticking out. I milled off the head carefully and removed the plate. Surprisingly, the remaining stud was finger tight and came out easily. SUCCESS! I'm going to replace these Phillip head screws with socket head (hex) cap screws so this doesn't happen in the future. They are 10-32 screws and not metric.
devils4ever
May 13, 2019
840
Another question for everyone. How do I remove the 3-jaw chuck? There are 3 socket head screws on the back, but there is no way to access them.
Obviously, they were put in somehow. But, I can't figure out how.
Aaron_W
Nov 14, 2016
2,337
Those screws just hold the chuck to the back plate, the chuck is threaded onto the spindle of the dividing head.
AdBlock Detected
I've Disabled AdBlock
