- Aug 29, 2011
- 15
I buddy of mine does alot of gardening, so this year he bought a used pea sheller, Well the gears were worn out, needed some delrin bushings, a little TLC Etc.
So i made this simple little dividing jig and put both gear blanks on the mandrel at the same time, I used a 36 tooth spur gear to divide 12 teeth, The gears i made are 12 DP, 12 teeth 14 1/2 degree preasure angle, Worked great
