- Oct 29, 2012
- 1,325
Have you ever wished you had a nice foot-thick cube of cast iron from which you could machine, say, an entire new lathe headstock? Or a 2ft long 4"x6" slab from which to machine a new cross slide? Or enough of it in convenient shapes that you could use to build up an entire CNC machine? If you have, then you probably found, like I did, that cast iron typically comes cast in shapes that were convenient for whoever cast them and what they were trying to make, and not so much for you to and what you're trying to make. You probably found out that lifting weights are junk iron, tractor ballast weights are made of gold, and durabar is actually made of platinum. You've probably watched a few casting videos, so you know it can be done, but it seems like a P.I.T.A. and there's nothing new or spectacular about it. If you're like me, then you have a junk forklift sitting in your driveway (that the scrap yard won't take because it's beyond their ability to scrap), and every day you walk by it and it flaunts its big beautiful cast counterweight hips at you, daring you to find a way to cut through a foot thick of cast iron. Well, I think I might have found it.
This particular janky P.O.S. happens to be a diamond wire saw.
Yes, it's made entirely out of unistrut. Yes, it's janky as hell. It's prototype, ya know, "for testing purposes only." If it works as well as I hope, I'll make something more permanent. Maybe out of welded square tube. Or not.
I know some things about diamond wire cutting as I used to work with subsea diamond wire saws similar to this:
But this one is different. Those offshore ones use a continuous loop wire rope with sintered diamond beads, about 12mm OD. This one uses single-strand wire surplus from the semiconductor industry (used to slice silicon ingots with very little kerf) and has about 0.3mm OD. It is something like a "portable" version of this:
I won't be able to join the ends of 0.3mm steel wire without leaving some kind of knot that would get hung up in the cut, so I won't be able to do it like I used to offshore. I don't know for sure, but from what I've been able to find online, it seems they have it on spools with several miles of wire and I think they wind it off a full spool, through the cut, onto an empty spool, and swap the spools once all the wire has passed through. They can the run the same wire several times before it no longer makes cuts that pass their muster.
My saw is like a hybrid between the two concepts. It's laid out like a subsea saw, but has a single bobbin wound with 1000+ ft of wire. The bobbin spins one way, paying out wire from one end, going out around a system of pulleys like the subsea saw, then wound back onto the same bobbin. It runs until all 1000ft of wire has been moved from one end of the bobbin to the other, then it stops, reverses direction, and runs 1000ft the other way, then stop, repeat.
Here's a video I shot last week. It should help illustrate how it works and provide context for the video that follows it.
After I'm done cutting through the forklift I'll either hang it from the ceiling in my shop as some kind of haphazard guillotine saw, or transform it into something more permanent like a large bandsaw.
Here's an update to the previous video that I just uploaded tonight:
And below is an early attempt at balancing the drum. This thing will be spinning 2700 RPM so it needs to be at least somewhat balanced. I am going to revisit the balancing now that I have the saw mounted in a more substantial frame (as opposed to sitting on Jack stands) and now that I have legit analog-output accelerometers (as opposed to mechanically coupled computer speaker voice coils) to measure the vibrations.
