- Jan 20, 2016
- 1,011
This was discussed to death awhile back.
I have a Drill Dr 750 and also sharpen by hand.
My thoughts are that the drill Dr. (750) works just fine if you take the time to learn how to use it properly. Using it wrong can produce less than good results. Particularly if you don't keep "grinding" until the Drill Dr. stops cutting metal. If you stop before then you are likely to get uneven and improperly ground flutes.
As everyone is aware sharpening by hand can produce excellent results. But then again, you need to learn the proper technique and have the "feel". Getting the "feel" requires practice.
Neither one is foolproof nor can either one sharpen a drill for a damn without training, practice and attention to the procedures.
