The weather here has been beautiful the last few days, so have been getting in a bit of shop time.
A customer asked me to build a drill fixture for drilling some wood parts for her project. Her parts are 1x2x12 inches with a series of hole in them so here's what I came up with.
So I started with the drill bushing holder, an aluminum 1x2x3 block, nicely squared up and ready to start chewing on.
And done. Nothing too magic here, just a normal setup. Note the relief channels on either side, Prevents crud building up in the corners and gumming up the works. But the next operation is more fun. I need to make the 5/16 drill bushings, but they need to be easy to replace and buildable with common hand and power tools that you might find in a home woodworking shop. So a 1/2-13 grade 8 bolt will work just fine.
Since I already knew exactly where the hole in the bushing holder is, it made sense to just use the the part as the fixture to drill the bolts. That way I know the hole in the holder and the hole in the bolt are exactly concentric.
Then I did a round over with a 1/32 R corner rounding end mill
And done
So next I need an aligning pin to drop in the hole to locate the part for the next hole. So looking around the shop I found the perfect head for it and I have hundreds of them. So that and a 1.5 inch long shoulder bolt is the perfect combination.
We make several hundred of these in each run. 5/8 OD 303 SS.
So part it off and drill & tap for 1/4-20 and instant aligning pin with an ez-grip knob.
Now that's working close to the chuck, about 0.010 clearance. ( yes I carefully checked the clearance before starting the lathe) No problems, it parted off nicely.
Then I parted off the head of the shoulder bolt and rounded over the end with my trusty Harbor Freight round over router bit.
And done
So next is the base and the fixture guide
Square up the MDF base. The end mill is 0.015'' off the table. I set the max depth with a feeler gauge under the end mill. I trust my machine and I know the Z axis repeats to +/- 0.0001 consistently.
Squared up and the screw pilot holes drilled. You almost can't see the pilot holes just above the blue lines.
Then drill and screw down the plastic guide for the next operations.
Remove the clamps to allow unrestricted access to the top, finish drilling the mounting holes and screw down. Also drill the alignment holes.
And machining is complete, well almost Note that there is no chamfer on the drill clearance hole. It is on size. This is to help prevent tear out of the wood as the drill breaks through, I have also let her know to use brad point bits. Should make a clean hole.
I had to put a little divot in the side of the drill bushing holder to clear the larger knob than I was originally going to use.
Still need to build the end stop, I'll do that in the morning. But otherwise complete.
After I build the end stop, I need to make another drill fixture for a mating part. I'll post that in this thread tomorrow. This should have been about a 3 hour project, but I managed to stretch it into about 12 hours. I just don't move as fast as I used to. I'll be lucky if I even make minimum wage on this one.
And done
And done
