[4]
Drilling across a threaded shaft's diameter and/or threaded adapter's diameter
[3]
[10] Like what you see?
Scott(GA)
Active Member
May 26, 2014
31
In the JET Lathes, Mills, Saws, Etc. Forum I posted my efforts at adding a Z-Axis Powerfeed to my JET Milling Machine.
Pretty much the last step of the installation is to drill a 5mm hole through the Powerfeed shaft & Manual Crank Handle adapter and insert a Spring Pin.
I had thought I'd take the adapter off the shaft and drill the hole through it using the Milling Machine but I was concerned that doing so - without something inside the adapter to protect the threads - might cause problems.
The issue is explained in detail in the Powerfeed thread: Here's a link to the actual POST that details things with pictures and such.
As I was having issues finding a bolt that matched the internal threads of the Adapter, I was wondering if drilling through the Adapter without something in the hole would be a mistake.
Scott
Dave Paine
Brass
May 10, 2014
813
I think the issue is burrs on the inside when the drill exits the top side of the hole. May also get burrs on the bottom side. If I were doing this I would prefer to have a tap to clean up the burrs. If you make a 7/8in x 12 tpi plug and screw this in, you may still get burrs and may have a challenge getting the plug out.
7/8in x 12 tpi is a special thread. Taps exist, just are not cheap.
7/8in x 12 tpi tap at Victor Machinery.
markba633csi
H-M Supporter - Gold Member
Apr 30, 2015
3,166
Making a "pseudo-tap" would be a good way to avoid the burr problem- make a threaded shaft and mill a couple slots lengthwise on it, like a tap. Then use it to chase the threads in the adapter after you drill. You may not even need it if you use a nice sharp drill, a dull drill will leave a nasty burr for sure
Mark
P. Waller
H-M Platinum Supporter ($50)
Mar 10, 2018
901
There are methods of creating such holes without burrs but few hobby shops would have the equipment for it.
[6]
[5] [7]
