- Dec 3, 2013
- 1,844
I need to drill precision holes in 3mm to 12mm" thick acrylic. The holes range from 0.6mm to 3mm in 0.2 increments. Specialty drill bits for acrylic use 60 or 90 degree points with zero rake cutting angles. Standard point drill bits grab too much and chip the hole edges. They also do not produce clean interior surfaces so they won't work. The holes must have clean crisp edges. I have not been able to find any commercially available drill bits in these sizes. Unless someone has a suggestion for a source my other option is to regrind standard bits. In that case I would be looking for a reasonably priced tool or fixture that could grind those angles.
