[4]
Drive Pulley has some play
[3]
[10] Like what you see?
Boris Ludwig
H-M Supporter - Silver Member
Oct 30, 2016
123
The pulley on the motor shaft has a key way and a grub screw. The grub screw feels tight but over time the the pulley is able to rock on the shaft. It gets noisy and I have to loosen the screw and tighten it up again.
Is there anything I can put on the shaft and key to take up the slack between the pulley and shaft? Something that wont be a pain to disassemble when I need to make a change. Or should I get a new pulley?
Z2V
H-M Platinum Supporter ($50)
May 10, 2017
714
Have you thought about using shim stock? How much slack are you talking about? Does the key fit good and tight in the key ways? Just off the top of my head.
Boris Ludwig
Oct 30, 2016
123
Its only slight but enough to cause noise that bugs me. The key is tight on the shaft. It's the pulley that's a bit big. Slides on easily but no side play. It's just able to very slightly turn on the shaft. Key way in the pulley is just a tad big.
I haven't tried anything yet I just thought I'd ask first to save myself time.
markba633csi
H-M Supporter - Gold Member
Apr 30, 2015
3,170
You might try some removable Loctite (like 242) either on the setscrew or on the shaft itself, or both. Also, you might want to consider adding a second setscrew to the pulley if there is a suitable spot to drill and tap another hole. Sometimes putting two setscrews one on top of the other helps.
I had the same problem as you with my bandsaw motor pulley (no key, just a flat on the shaft) and adding a second setscrew on the next sheave worked for me.
Mark
whitmore
Active Member
Mar 3, 2017
368
I had such a problem, and the fix was to run a reamer down the pulley hole; it was slightly (out-of-round? conical?),
but after making it circular, the problem went away. No guarantees, but if you can't fit a shim in to tighten the
fit, it could be that the hole isn't round enough to achieve shaft contact.
BtoVin83
Active Member
Aug 30, 2017
197
If the hub has enough material can you make your own version of a taper lock or QD hub?
chips&more
Mar 19, 2014
2,472
Mark
Hi Mark, you have the right manufacture but I think you want to try the 660 stuff. I used the Loctite shaft repair on a worn out table saw pulley/shaft and I was totally amazed!!!!!!! I could be wrong on the Loctite number? It was gray in color. I remember the instructions saying it was for a temporary fix until you got the replacement parts. But the stuff lasted for years and never failed. I will try and find the tube in my shop. And try looking up shaft repair products made by Loctite…Dave
markba633csi
Apr 30, 2015
3,170
242 is probably not the best choice but I've used it for all kinds of oddball repairs
It IS amazing stuff- how did we ever get by without it? :cool:
benmychree
John York
Jun 7, 2013
2,858
I had the same problem with a Delta Rockwell drill press, it made an awful racket; Loctite was the answer.
Cadillac
Brass
Mar 12, 2018
641
When you have a pulley mounted on a shaft with a key way. There should be two set screws. One directly over keyway to engage key to shaft. The other mostly is 90* from keyway. To lock pulley to shaft. If you put 180* from key it might want rock naturally because of the two pressure points. And red LocTite is always good insurance.
Boris Ludwig
Oct 30, 2016
123
The pulley hole is round but the key way in the pulley is I tad too wide so the pulley rotates on the shaft. When I just tighten it's ok but after a week or so it's back to noisy normal.
Boris Ludwig
Oct 30, 2016
123
In my case there is just one on top of the key.
The pulley rotation is only small but enough to be noisy and it probably increases wear which may mean eventual failure. Hey, I'm still new at this so I'm not sure.
Boris Ludwig
Oct 30, 2016
123
Make a new pully.
If I could I probably would like to try it one day. I'm still a bit new at this and I'm not sure I have all the tools I need to complete such a task.
dave_r_1
Active Member
Feb 3, 2016
448
Maybe make a new key that wedges in the pulley a little closer, so it will have a little step between the where it goes in the motor shaft keyway and where it goes in the pulley keyway?
Cadillac
Brass
Mar 12, 2018
641
You won’t wanna keep running like that with a wobble. Eventually it’s gonna wear your motor shaft from rockin.
With all the things wrong with that pulley. Bore loose, keyway to big, only one setscrew. I would just make or buy a new one and stop pulling your hair out on this. That pulley should be easily sourced and really overall size can be changed for your speed request.
Boris Ludwig
Oct 30, 2016
123
You know it has no sideways play on the shaft just rotational as the key way in the pulley is a tad big so when the set screw comes loose as it does every month I pull out my hair.
But you're probably right, I probably ought to change it.
whitmore
Active Member
Mar 3, 2017
368
There's an old variant of a key, a stepped key, that fits mismatched shaft/pulley keyways. It oughtn't
be impossible to make one, That'd be quicker than buying another pulley.
Another outlying possibility: could you put a blunt-point setscrew in, and maybe a bit of brass shim at its
tip, then maybe friction on the moving key wouldn't turn the setscrew (it's a bearing, kinda). At a
prior job, we had fits on a bunch of clamping screws that got loose in shipment: same thing,
minor slippage was enough to loosen our lockwashers as the truck went over a bump.
There's occasional torque during shipping jolts, like you're seeing when the pulley key
exercises its slack keyway...
francist
Sep 5, 2013
1,135
Stepped key is a great idea -- except I'm not seeing a matching key way in the shaft. In either of those shafts, actually. Could be a big part of the problem, it's just relying on the grub screw to limit rotation.
In the absence of a proper key way, at least put a flat on the shaft. Less opportunity for screw to wiggle back and forth.
-frank
whitmore
Active Member
Mar 3, 2017
368
Ooh, good point; I assumed it was a simple key. There could be a Woodruff key, the shaft end
wouldn't show it. Don't think there's any tradition of W-key with a step, though.
Odd image shows up that might be something like that, here: <http://a.co/903nofJ> (or
the long form, <https://www.amazon.com/OES-Genuine-Camshaft-Woodruff-Mercedes-Benz/dp/B001G7EG4C> ).
francist
Sep 5, 2013
1,135
Agreed, could be a woodruff. Or even a stopped key way which wouldn't present from the end. However, I think either of those would be rare and unusual occurrence. Especially on something this small (as opposed to a hydraulic shaft or something).
I have cut in the occasional key way using a Dremel tool, but it's not a great way to do it and could easily make things worse.
-frank
Boris Ludwig
Oct 30, 2016
123
I'll take a few photos today with it pulled apart so you guys can see the key, keyway in the shaft and the pulley. I might make it all that much more clearer.
Boris Ludwig
Oct 30, 2016
123
Not sure this really shows much but I decided to put some brass shim between the key and the pulley keyway and its a bit tighter I hope it works.20180526_111603.jpg
Boris Ludwig
Oct 30, 2016
123
Sorry BtoVin, I missed this, now I'm going over this thread again in case I missed something. So I'm wondering what a QD hub is.
tq60
Brass
Jan 11, 2014
711
Google 2 part pulley hub and that should give an idea.
It consists of a hub that slides on shaft then pulley or body slide on.
2 screws pull it on and same screws used in different holes to remove.
Simple and elegant.
[6]
[5] [7]
