Planning on picking up a mill tomorrow and hauling it home . The mill has a DRO with a severed cable . Can these be spliced or replaced with a generic cable ? I know it's an older DRO and not sure what brand off hand .
If it's a digital signal, like = +5V and ground, then yes, you can splice them. If it's much older and a sine wave output, probably you can. Even with a 1um DRO, the rate of the signals isn't that fast. For an experiment I was doing, I got 1 DRO edge about every 220 microseconds. 400 RPM lathe at 0.1mm/rev. I'd try splicing the wires. It will probably work fine. If it doesn't, then come back and ask more questions.Planning on picking up a mill tomorrow and hauling it home . The mill has a DRO with a severed cable . Can these be spliced or replaced with a generic cable ? I know it's an older DRO and not sure what brand off hand .![]()
Hey Thanks Wobbly , I thought I spliced one years back and it worked fine although I think it was an Accurite2 . How's the daughter making out ? Everything good I hope .If it's a digital signal, like = +5V and ground, then yes, you can splice them. If it's much older and a sine wave output, probably you can. Even with a 1um DRO, the rate of the signals isn't that fast. For an experiment I was doing, I got 1 DRO edge about every 220 microseconds. 400 RPM lathe at 0.1mm/rev. I'd try splicing the wires. It will probably work fine. If it doesn't, then come back and ask more questions.
Well, she's still working, but things aren't exactly "normal". Your daughter ok, as well?Hey Thanks Wobbly , I thought I spliced one years back and it worked fine although I think it was an Accurite2 . How's the daughter making out ? Everything good I hope .![]()
So far , so good .Your daughter ok, as well?
