[4]
DRO on 7x10 Lathe (1st Step to CNC Conversion)
[3]
[10] Like what you see?
paulctan
Newbie
Oct 4, 2013
3
Hi Everyone,
I just mounted a Chinese iGaging (clone) DRO on my lathe. I picked up two of them for around $65 from ebay, but you can also get them from Amazon - http://www.amazon.com/iGaging-Magnetic-Remote-Digital-Readout/dp/B003JUII2A/ref=sr_1_2?s=hi&ie=UTF8&qid=1382818895&sr=1-2&keywords=igaging
I only got one axis done so far but it worked great! These things are awesome, I cut down my working time from 40 minutes per part to just 15 minutes with only one slide installed. It will be much better when I get the cross-slide gauge installed, and even better when I CNC convert my lathe.
I can verify that the repeatability of the gauges is quite good (some people on other forums elsewhere have complained about that but I saw pretty much perfect repeatability). Here is a picture of the mounted DRO:
Here's a picture of the slide after use (I think I will put some tape to cover up the holes.)
I screwed in one side of the mount as you can see, and I just crazy glued the other mount to the slide. At first I thought that might not hold, but the crazy glue seems to be holding fine.
Now, the problem I have is trying to figure out how to mount the cross slide gauge. Here's a picture of the slide, and any tips would be much appreciated.
I'm building an electronic interface to the iGaging slides so that I can ultimately use it to servo control the lathe for CNC using a Beaglebone Black. I'm going the closed loop servo as an experiment instead of using steppers. In the meantime, I'll probably build a DRO interface similar to what Yuriy did - http://www.yuriystoys.com/p/android-dro.html - but using the Beaglebone Black instead. Here are some pictures of that work so far:
Connecting a signal tap to find out what the signals look like between the controller and the scale.
Signals to and from the iGaging DRO.
My setup to attempt to read those signals using a Beaglebone Black.
You can also see more detailed attempts on my blog at http://exadler.blogspot.com.
I'll probably get a few boards made of the final product that will at the very least give you a DRO reading. If anyone is interested, let me know, and I'll get a couple extra boards made at the same time (it's only low cost if I order a larger quantity at a single time. e.g. it will cost $79 for 5 boards, and $129 for 50 boards).
Paul Tan.
http://www.exadler.com
Maxx
Jun 25, 2013
165
I am also doing the iGaging DRO upgrade to my lathe SB 10K.
I have the carriage scale mounted and found the 3 times a second refresh rate bothersome on faster cuts.
I'm hoping this is in the factory display and not set by the read head circuitry.
I am doing the Arduino/Bluetooth interface for my HP Touchpad that Yuriy came up with.
I will be posting my own thread after I'm a little further along.
I just need to solder the jacks to the board and flash it at this point.
Like you I am still working out the cross slide mounts but I'm adding a taper attachment so that has complicated my install.
Good luck and I will be following your thread.
Maxx
[5] [7]
