Several years ago I added a DRO PROS EL 700 to my small Grizzly knee mill. When I bought the DRO package I also purchased the DRO PROS touch probe because it was sold at a reduced price with the DRO. I have used the touch probe a couple of times and sure enough, on an early attempt at usage I broke the ruby tipped ceramic probe. Lesson learned. I replaced it with an all metal probe and thought I did a pretty decent job of dialing in the new stylus to run on center with the spindle. I then put the touch probe away and haven't used it for quite a while. I recently brought the touch probe out of hibernation and wanted to check it for true center line and it is off by about .006". I tried to adjust it to true center and it took what seemed like a very long time to get it true. Can someone give me any ideas on how you calibrate, or go through a process of getting the touch probe to run true with the spindle center line? Do you loosen the 3 contact retainer ring screws before adjusting the 3 stylus grub screws? I remember hearing something about "loosen the lows and tighten the highs" when doing this process, but I am not sure I know what that exactly means. I also noticed that when I was finished with the probe calibration and removed and reinstalled the unit in my spindle it wasn't true anymore. Is that because the probe shaft wasn't in the same orientation in the spindle?
Thanks for any help in this matter.
Rick H.
Rick H.
