Drummond 5" double bed tailstock
MarkNotts
Jan 10, 2019
14
I am in need of a tailstock for my Drummond 5" double bed lathe, the one that came is too small, I bought another and the base does not fit, the top bed on mine is 120mm wide, the bed of the 5" lathe it came off is 105-110mm wide and there is not enough material to mill the dovetails wider, the front dovetail will need atleast 15 mm milled off so the base can slide back on the rails so the 2 rear locking bolts can slide through to the rear dovetail block and they are being blocked by the rail, there is not enough material at the front to do this.
