- Dec 9, 2016
- 1,133
Honestly, I don't think this is any different then single point threading!
Don't know if it is the same guy,but I saw that oneWasn't there a thread where the guy did this with a broken die also ?
You can cut a tapered thread.Honestly, I don't think this is any different then single point threading!
I havent had the need to yet but I guess I dont understand the question! Wouldn't you still need to lock in the split-nuts with the lead set to the correct pitch to use this method just like you would with a single point? And if you set the needed taper into your lathe setup wouldnt that be the exact same thing with the exception of the tap having multiple follow up skim cuts?You can cut a tapered thread.
YesI havent had the need to yet but I guess I dont understand the question! Wouldn't you still need to lock in the split-nuts with the lead set to the correct pitch to use this method just like you would with a single point? And if you set the needed taper into your lathe setup wouldnt that be the exact same thing with the exception of the tap having multiple follow up skim cuts?
Ahh! Ok now i see it, the tap itself is tapered, which cuts the mirror image when used to cut this way, correct?
I wondered that as well but looking at the grind on the flutes, it appears not. (around 10:20 in). Also, the tap threads look like r.h.I basically posted this just to show that there is a lot of methods doing the same thing. I do wonder, is that a left hand thread tap? If you look at the cutting edge side he used.
Looks like a right hand thread to me. Lathe is going counter clockwise and the thread is climbing towards the headstock. I don't think there's any hocus pocus going on with the tap because it's not turning so it just a form tool in this application. I think a left hand tap would reverse the lead angle. That said, I freely admit I'm freaking OLD!I basically posted this just to show that there is a lot of methods doing the same thing. I do wonder, is that a left hand thread tap? If you look at the cutting edge side he used.
