Episode 12B || Pistons and Rings
[Continued from Part A…]
Piston Rings
Each piston uses three rings: the upper two are compression rings and the lower is an oil ring. The compression rings are solid, whereas the oil rings have some through-slots and grooves to help distribute oil to the cylinder walls.
The initial machining operations for both types of rings is identical. As has been touched on in several earlier posts in this thread, the method of ring construction described in the drawings is pretty darn ingenious. It doesn’t require any guess and check, or calculations, or heat setting. And the result is a well-sprung piston ring that is perfectly round when it’s fully compressed in the cylinder bore. It goes something like this:
(1) Chop off a chunk of cast iron about 3 inches long. I had some 1-1/4” diameter rod, so that’s what I used.
(2) Chuck it up at the lathe and rough bore to about 7/8” ID and rough turn the OD to about 1”.
(3) Bring it over to the mill and mill a full-length slot 0.080” wide. This width will be the amount of spring present in the ring after you’re done making it. (I should have put a chock in the other side of the vise. But I didn’t. Sue me.)
(4) Bring it back to the lathe. Chuck it up TIGHT so that the 0.080” gap closes all the way. Any more stickout than about 1” and the gap won’t close all the way.
(5) Finish bore the ID to 0.875” and finish turn the OD to 0.944”, which is the same as the cylinder bore, maybe a thou less.
After this step, construction of the compression vs. oil rings differs. The compression rings are easy, just:
(6) Slip a ‘parting cap’ over the end of the tube and part off a ring to the appropriate length. See my discussion of my epic fail a few posts earlier to see just how important that parting cap really is.
(7) Repeat step 6 until you’ve got enough rings, plus a few extra.
After parting off, I was left with a burr all the way around the ring. I used the sharp corner of a V-block to knock it off. Then a few swipes on some 220 grit sandpaper, both sides. Viola!
Construction of the oil rings was more complex. I left the finish turned and bored cast iron tube in the lathe chuck and brought it over to my 12” rotary table on the Bridgeport, lying flat. I chucked up a 0.015”-thick slitting saw in my new-to-me quick-change setup (!!!!!). Construction basically went as follows:
(6) Center everything up, and note the angle on the rotary table where the ring gap is located.
(7) Slit off a very thin slice of the tube right at the top to make sure everything is flat and to set a Z=0 location.
(8) Move the quill down such that the slitting saw is centered on the ring thickness. Cut a 0.010”-deep slot around the full perimeter of the ring.
(9) At the 6 locations specified on the print, plunge 0.065” into the ring to get the through-thickness slots.
(10) Move the quill down to the bottom of the ring. Install the ‘parting cap’ and part the ring off.
A few swipes on some sand paper and she’s good to go! An insanely delicate looking part, but quite frankly, not all that difficult to machine if you’ve got the right tools and cutters.
All the rings and all the pistons still need a little bit of debur and some fine adjustments to make sure everything fits, but I’ll save all that for closer to final assembly. (Not pictured are a bunch of extra rings, both types. Just in case.)
Anyway, some really nice looking parts in this post! Sure is coming along now.
Next up: CLEAN EVERYTHING! There’s cast iron dust all over my shop, on all my ways, and in all my chucks.
TIME ON PISTONS AND RINGS: 22 hours
CUMULATIVE TIME: 212 hours
