- Feb 1, 2015
- 9,578
A bit of advice re: the encoder and display connectors. Mark the ground pin on the Launchpad board and on the encoder connector and the +5 pin on the boost board and the display connector with a Sharpie. The visual aides are added insurance against reversing the connections.
Here is some information on the encoder.https: //www.ia.omron.com/product/item/2453/
Looking at the pin assignment of the Lunchpad, I don't believe that the encoder would be damaged by reversing the plug. It would put the supply voltage across two output pins (2A & 2B). If the Launchpad port is damaged, you should be able to use J13 by changing the switches. https://github.com/clough42/electronic-leadscrew/blob/master/docs/images/LaunchPad.jpg
