[4]
Electronic Project: Battery Charger
[3]
[10] Like what you see?
Norppu
Active Member
Jun 15, 2018
74
This is a battery charger in steroids. You can charge Pb, NiCd, NiMh, LiFe and LiMn batteries with this one.
The output voltage will adjust itself automatically once You have connected the battery and chosen the cell type regardless the number of cells in series. Then just choose the output power and press go.
The maximum current is around 10A and maximum voltage is about 48V.
The project files include the PCB design and the AVR code. The physical appearence of the charger is up to You ... :)
brino
Jan 2, 2014
3,685
Neat project!
Thanks for sharing.
-brino
David S
Nov 18, 2012
1,329
Is it possible to put the schematic in another format? I can't open the file.
David
Norppu
Active Member
Jun 15, 2018
74
David
Please, look at the eagle folder in my server. You should find a PDF file in there. Unfortunately the schematic seems to be a PostScript file in the zip.
The directory is here
You can also look other projects in the Hobby Machinist folder
[5] [7]
