- Mar 26, 2018
- 2,724
Yeah, this is a tough decision. Having more space and basement access would have me sell this lathe and go for a bigger one. If nothing else, I'd get more rigidity and mass.
I'm not familiar with GT2 belts and pulleys. Are there any that would fit the main spindle gear? The pulley's ID would have to be matched to the spindle's OD. It looks like a set of special wrenches are needed to remove the current setup. I'm not as concerned with the lead screw shaft since it's a lot smaller.
Good thing you have a lathe to machine those pulley hubs
GT2 is a small pitch curvillinear profile pulley. They are good to about 2HP and have lower running noise than most belts. Fabric faced belts add to the noise reduction.
You could probably get a 10" lathe down to the basement without too much hassle. The headstock can be removed to save weight.
