Emco Compact 8
What about some grizzly gears, I used some for my Compact 8 and work just fine, steel too! Wished I had a QCGB ;)
The grizzly gears I have found all seem to have key ways instead of the role pin hole from the Emco design.
As long as the gears are the same otherwise, you could probably just ignore the keyways and drill a hole to match the Emco pin.
True, I wonder if most gears are hardened. And if they are, are just the teeth hardened or the whole body of the gear too.
Many gears are hardened, but I doubt Grizzly bothers to harden their change gears. They don't really need to be high-performance gears, and hardening would cost extra money. The change gears on my generic Taiwanese 1440 lathe are definitely not hardened - a file cuts them easily.
