I pulled the trigger on an Emco v13 and I am in the process of cleaning it and learning its ins and outs.
All the threads on the machine are metric, and I am looking to get some leveling feet. There are a total of 4 pairs of holes in the two bases of the machine - each pair has one threaded (I.d measures just under 14mm) and one non threaded (measures at .780 ish close to 20mm).
1) anyone know the pitch for the threaded portion?
2) Can i just use the non threaded hole for the leveling feet?
Also open to recommended brands of feet. Mcmaster has some that look good, and I am unable to use the leveling pad that PM sells as the surface is uneven beneath the cabinet to where the holes are drilled ( the plate the holes are in is recessed).
Thanks in advance,
Mike
Thanks in advance,
Mike
