For the veterans out there, what is a good box I can buy for my vfd? It will be inside and mounted in on the wall. Possibly inside the garage (worst case).
I have the exact VFD you have and I made my enclosure from .065" aluminum deck plate, (the metal supplier had scraps that were a usable size). It was easy to weld up and two L shaped pieces into a box then add the back and fasten the door with hinges and some thumb-screws to hold it closed. I added a lexan window so I could see the readout then mounted it to the wall and ran cable to a box I got from digi-tech to mount industrial type switches the speed potentiometer and soon a tachometer that will read off the toothed pulley that drives the spindle. I looked to try to buy one but anything deep enough for the WJ200 was pretty expensive.
The tachometer needs a single steel pin/screw on the rotating part. I drilled and tap a 6/32 hole in the spindle drive pulley and machined a little pin.
