- Sep 14, 2014
- 2
I have the above referenced mill. When standing in front of the mill, there's what the manual calls a thumb screw on the right side of the mill. This thumb screw must be loosened to change the speed belts. Then the motor is pulled toward to the front of the mill allowing the belts to loosen. Very simple right? However, on my mill the pin that is held out by the thumb screw will not release and move in to the machines as it's supposed to. You can rotate this pin, but I can't get it to move inward so the belts can be released and re positioned. Has anyone else had this problem? My mill has 4 pulleys which seems to be slightly unusual for this model.
