Refurbishing an Enco 110-2031 12X58 lathe and have a couple of questions.
Of the two drive belts it seems that the forward one requires disassembly of the headstock and the rear belt the motor cannot be replaced at all due to a press fit rod that is in the way. I am aware that there are powertwist belts but unsure if there is one for this machine (belt is a B33)
The motor belt is the one I need to replace.
The second question is how do you add new oil to the spindle bearing reservoirs? There are two oil sights on the front for indication and drainage but only the left bearing has a spring loaded oil cap?
Thanks for the great group.
Steve
Steve
