Enco power feed
jdjax
Jan 27, 2015
19
Is there an adjustment for the x axis power feed, it is jumpy at slow speeds?
C-Bag
Ned Ludd's bro
Feb 9, 2017
1,680
There is a height adjustment on the end of the add on casting that adjusts the enmeshment of the drive gear to the driven gear on the table. If it's too tight it will "jump". Good grease is a must. I use a synthetic water proof grease that has Teflon in it. I've seen first hand how this stuff is incredible at hanging in there when other greases quit. It's also imperative that your ways are lubed. This is a hassle because all we've got is those little ball Oilers and really you should pump them up in several places on the travel IMHO and you can do that with the front but only close to the ends of travel in the back. Use only good way oil, not motor oil, makes a HUGE difference. And lastly, when was the last time you pulled and cleaned your X&Y lead screws and their half nuts? This is what made the biggest difference on my RF30. Once again good grease on them is the secret.
jdjax
Jan 27, 2015
19
Thank you both for the replies, I will get to work on your advice.
Cadillac STS
H-M Platinum Supporter
Jul 20, 2012
877
Maybe check the lead screw from the bottom to be sure it is clean and moves freely. Clean and oil it if it needs it.
AdBlock Detected
I've Disabled AdBlock
