[4]
Enco (RF30) 110v wiring
[3]
[10] Like what you see?
tcweb
H-M Supporter - Silver Member
May 25, 2016
64
I'm sorry for posting, there must be dozens of posts on this topic, but I think I've found them all, and they don't apply to my mill.
I have a new (to me) enco mill drill. About 600lbs of coolness, and was able to move the motor jumpers to get it to run on 110v.
The ONLY issue is that the forward/reverse drum switch is backwards. I figured it would be easy - locate the capacitor/start winding, reverse the leads, and I'd be good.
Not so easy, apparently - my drum switch has 12 contacts, and without taking everything apart, there's no way I can map it out.
I'm hoping someone has an earlier enco mill/drill that uses the same reversing drum switch and 2HP Chinese motor. (4L-90-4, I believe)
I'll attach the pics that I have.
tcweb
May 25, 2016
64
I will take more pictures, and provide any additional details that may be needed. I'd like to document this well enough for someone else coming along who has the same or similar setup.
Lastly, my assumption is that reversing the blue and brown wires at the motor terminal block may accomplish what I'm looking to do... (those are the terminal blocks marked Z1W1, Z2W2). But since this config may have been wired wrong by a previous owner, I don't want to risk making changes until I'm a bit more confident.
Norseman C.B.
Active Member
Dec 21, 2013
280
Personally I prefer 220v as it has less draw on the power source
and more efficiency for use, MORE POWER MAN !!!!................
tcweb
May 25, 2016
64
I can't be sure that someone didn't bungle up the wiring before I got it...it may run backwards at 220v as well. :)
markba633csi
Gold
Apr 30, 2015
3,440
Swap the Z1 and Z2 that should do it.
Norseman is correct, 220 volt is more efficient and your switches last longer
Mark
tcweb
May 25, 2016
64
Thanks, I will try it. I wish I could use 220v, but my garage is detached from the house, and is only wired for 110v.
tcweb
May 25, 2016
64
Sure enough, swapping the blue and brown wires above changed the direction of the motor, so now forward and reverse match the drum switch labels.
[6]
[5] [7]
