I just discovered the text wizard in Mach3 and made a few practice runs in aluminium that were somewhat successful.
I don't have an appropriate cutting tool, so for the first test I used a 1/8" end mill and that was okay for text 0.5" tall. I would like to add some much smaller text to a project I'm considering, so using a small pointy diamond cutting tool designed for a Dremel tool, I managed to engrave some fairly legible text 1/8" tall. No idea how long the Dremel bit will last.
I did this with fairly low turning speed, about 1000 RPM, the fastest I can go without changing the belts, and 0.005 depth for the first test and 0.010 depth for the second test. Looking for suggestions for a suitable cutting bit and any hints to optimize results.
Thanks
Thanks
