ER 32 Collet Blocks
Buffalo21
H-M Supporter - Gold Member
Feb 24, 2018
618
I had ordered the square and hexagon ER 32 collet blocks from LMS, with my current run of somewhat poor shipping luck, I was expecting 2 weeks. I already have the collet blocks in 5C, so I was not being held up on jobs. So 5 days after I ordered it, it arrived. I was surprise. They seem to be a quality piece with the HHIP logo, I was surprise by the heft, they weigh almost as much as the 5C blocks.
I much prefer the wrench/nut tightening vs the 5C ring that needed me to remove the collet block to change out work pieces. Hopefully they will work out, I’ve use the 5C versions quite a bit.
Old Mud
H-M Platinum Supporter
Aug 8, 2016
399
Do those blocks lay flat in all positions without interference from the rings ?
Buffalo21
Feb 24, 2018
618
No, the ER 32 collet nut is bigger than diameter that the body of the block. The nuts are about 2” in diameter and the bodies are about 1-5/8” side to side. It shouldn’t be a problem for me, I want the nut to over hang so I can tighten it or loosen it, without removing the block from the mill vise.
Old Mud
Aug 8, 2016
399
Ok thanks i guess that won't work like my 5C blocks.
Old Mud
Aug 8, 2016
399
I always use my collet blocks in the vise, so the back of the nut works very well as a stop. I remember wondering if not being able to lay them flat would be a disadvantage, but I've yet to find that the case.
I use my 5C collets with blocks on a flat angled bed to sharpen my end mills. Couldn't do that with my set up if the nuts or rings were bigger than the blocks.
Joe in Oz
Sep 24, 2010
142
Have a look at "my" ER collet blocks. They are 12 sided - so only one needed to cover 4 sided and hex blocks, The bodies are bigger than the nuts and can be stuck directly to a mag chuck or held in a vice by opposing flats as well as always sitting on a flat:
I just developed them, I'm not the manufacturer. They are really good quality and I no longer get any benefit from posting about them (I sold the rights to my toolmaker friend who manufactures and sells them).
http://www.mag-pro.com.au/goods.php?id=469 and http://www.mag-pro.com.au/goods.php?id=252
devils4ever
H-M Supporter - Silver Member
May 13, 2019
306
Hmmm. I like. I was thinking of purchasing the LMS ones, but this one looks more versatile. I don't see a tolerance spec listed. The LMS ones are 0.0005".
Joe in Oz
Sep 24, 2010
142
Sorry, I can't tell you.... I CAN tell you they were made entirely in one fixture on a live spindle VMS, so they are a good as the machine - and that was big and new. I've seen photos of it.
OTOH, I managed to get the prototype I made by hand to be accurate within a few microns by lapping two of the 12 sides after I had ground all 12.
So if you have the means to measure to 0.0005, the you probably have the means to correct things beyond that precision....
AdBlock Detected
I've Disabled AdBlock
