Ever see one of these before?
DAHoyle
When I acquired my Harrison lathe, it came with a couple of pieces of tooling. One was a JFK collet closer that needed a lot of work to get it cleaned up and running smooth. I imagine just about everyone has seen one of those before. There was another attachment that most of us are familiar with at least in theory, and that is a tailstock offset center for turning tapers without having to alter your tailstock offset. There are a multitude of them of a couple of different designs on Amazon, and I know that some folks have made their own. The one I ended up with is a commercially made unit that is unique from all the others I have seen. The center runs in a precision bore, is adjusted by an acme screw, and has a very robust locking mechanism that consists of a gib like part, and it is tightened down by a knob. The end of the knob has a recess and there is a 1/4 ball that engages the gib. The gib is not a gib in the truest sense of the word because it doesn't adjust lash, but is just there to lock the adjustment.
The entire thing is very robust, and if I had to guess, I would say that it is close to 10 lbs. That is a #3 Morse taper, to give it a sense of scale.
I have searched the web a couple of times and have found no information about the manufacturer, nor have I found anything similar. Any of you guys ever seen one?
Seen some simple designs for offsetting the TS.
This is not one of them!
Very nice design and execution.
Congratulations!
A simpler, cruder "live centre" version is available for the 7x series mini lathe, in fact, any lathe with an MT2 T/S. I have used mine a few times and find it exceptionally useful and much better than off-setting the T/S itself, which can be a real ball ache.
The only "down side" is the room it takes form the working envelope, but swings and roundabouts aside, I will take the small loss of working envelope over resetting my T/S alignment every time.
A very useful accessory to have "in hand".
It's for cutting tapers, I have one but never used it, and they sell them on e-bay.
Yeah, I know what it is, and I know they sell them on EBAY. I was asking about this particular one. It is a beast and it is old enough that the manufacturer shows up nowhere online.
