Excellco 602 Mill
The tag says LPK there is also a BC on thetag, but off in the corner.
Sent from my XT1254 using Tapatalk
Man, that is an old one....I think that the only way to determine its age is to do a carbon-14 analysis on it.
I considered replacing it, but it works....
Just an update. I've been running for a while now and I love this mill. I have a vfd from Amazon that's working great. I also mounted a light. The quill feed, variable speed and injector are all working flawlessly.
I also added a Chinese x-axis power feed to replace the factory 3ph geared unit. I couldn't find any information on others doing this. It required me to make table end cap, cut a slot for a woodruff key in the lead screw, and Fab a way to install a tapered roller bearing to replace the captured bearing originally located on the table. If there's any questions let me know, I'm happy to help.
what size of drive belt i need for my 602 excello 9by42 tabe 2 hp thanks and where i can get
Assuming you're asking about a variable speed head, If your mill head reads XLO, the belt is a Reeves 107360 (cross references to Gates Canada 2322V364).
Possible source: https://www.vbeltguys.com/products/p107360-reeves-pulley-corp-oem-equivalent-variable-speed-belt
or https://www.amazon.com/REEVES-PULLEY-CORP-P107360-Replacement/dp/B00NUQDWHY
If your mill head reads EX-CELL-O, I don't know the p/n. It may be the same one.
For the Excello head you need 1922V321 belt.
According to the manuals I have....
manual # 52741 with XLO 1 1/2 hp and 2 hp head assembly 52-11880 Reeves 103317 = 1922V321
manual # 52672 with XLO 1 1/2hp..................... head assembly 52-11880 Reeves 103317 = 1922V321
2 hp..............................head assembly 52-11882 Reeves 107360 = 2322V364
manual # 52981 with EXCELLO 1 1/2 hp and 2 hp head assembly 52-15200 Det 151 (no belt number specified)
This is one of the problems with Ex-Cell-O's documentation. If anyone has additional manuals, I would be interested in seeing them
Thanks
Chris
@ChrisW
Can you post a PDF of manual # 52741?
I have the other two you mentioned.
