[4]
Excello Ram repair
[3]
[10] Like what you see?
CPL_Guimonster
Active Member
Jan 6, 2016
33
I recently purchased my fathers dream Excello 602.While trying to advance the ram,he whacked the handle with a hammer.(Pretty rusty)Now the handle spins around.I think he broke something. Has anyone removed the ram with it being broken? And what could have broke, a pin,a pinion gear?
FOMOGO
Sep 2, 2013
1,882
I would soak the ways with a good penetrating oil (not WD40) once or twice a day and give the back of the ram a few whacks with a block of wood and a 3# hammer, until you get some movement. On the broken part, I think you covered both the possibilities, or possibly a few broken teeth on the rack. The culprit will be revealed when you pull the ram. Mike
markba633csi
Apr 30, 2015
3,169
Being able to pound on things without breaking them is a fine art, honing this skill usually entails breaking a few select pieces along the journey.
You can probably fix or make whatever broke up there, even the rack could be replaced/repaired
Mark
ChrisW
Active Member
Jun 17, 2013
31
So, did you ever figure out what's wrong with your mill? As far as I know, the ram movement mechanism does not have a handle. You put a wrench on the hex end of the shaft to move it.
[6]
[5] [7]
