- Aug 23, 2013
- 970
Ok, my garage does not have 220 power so I need to run an extension cord to run my lathe. It is a 2hp 220v lathe that is about 7.5 amps. Would I be ok to run a 10/3 extension cord? Or will I need to go larger? The run from the house to the garage is 75', I am using a 50 amp circuit on the outside of my house that was used for a hot tub that I am moving an outlet over to the end of the house. I planned on swapping the ends of the extension chord over to match the lathe and the outlet. Any advice would be appreciated, extension chords are rated for 120v, so I just halved the amp rating of the cord.... Tim
