For my Precision 500 Horizontal Mill, as a beginner, I want to get some tool holders for horizontal face mill, by which, I meant to remove the NMTB #40 arbor, and put a tool holder on it.
I am thinking of getting a NMTB 40 to ER32 or ER40 (or even 20) and a set of ER collets.
I also saw some NMTB adapter with a fixed size hole and fixed size rod/bolt for holding shell mill cutter.
It's a hobby, so I don't want to spend too much. Chinese made is fine as long as the precision is good enough (that's a problem I heard).
So what would you advice me to do?
Another question is about the arbor, it's 7/8" size. I have a few cutters that size, but I have a lot of 1" size cutters. I am thinking of buying a 7/8" to 1" adapter for that. I also saw 1 cutter has an adapter that looks like a right that does just that. Would you recommend that or just buy/make 1" arbor? I am not confident enough that I can make a good arbor yet, so any short cut would be good. I also would like to get things running for now, not having a big project. Once I am good at things, then I will look into making the arbors. I am also thinking of using one of those tool holders that takes 1" hole (or open it up to 1"), then make a 1" round rod with a slot, cut a left hand thread at the end and I got an arbor. Would that work? Maybe I need to heat treat the rod?
