Fagor Help Needed For R-mode
bigearl67
Nov 17, 2013
49
This is one of those dumb little things that’s driving me half nuts. I can’t set my Fagor DRO to radius mode. I emailed Fagor and the Spaniards didn’t reply. It’s not supported on-line either. Does anyone know how to do this? It has the little icon for radius but I can’t get it to change. I’m frustrated. Thanks for any help. Earl
URL=http://s421.photobucket.com/user/bigearl67/media/fagor_zpsvqjnlojm.jpg.html]fagor_zpsvqjnlojm.jpg[/URL]
Your is a different model than mine but the 1/2 button on the bottom right does it on mine.
Greg
Greg, Yeah that's what I thought as well. It just don't work.
kd4dIJ,
Thanks for the links. I found the closest model too mine and in the manual it states that some models are not capable of Radius mode. No, really, 500 functions and that was apparently an "add on" to some models. Thanks again, Earl
I found this in several of the manuals. It my help You have to go into the setup to set it.
PAR04
Radius or Diameter. Independent for each axis. Possible values: 0
GAdius), 1 (dIAmeter) and 2 (COPmutated). The first case is
regular count, the second one is double count and the third one is
toggle between radius and diameter by pressing
1
2
The selection of these values rotates by pressing
Note:
When a rotary axis, the setting of this parameter will be
ignored.
kd4dIJ,
Thanks for the info. I'm still trying to figure out how to shuffle thru the parameters!
