- May 22, 2019
- 89
I have a grizzly g0791 lathe/mill and the tail stock end of reed rod has some play in the block. Either the feed rod is bent and that has caused the bore to expand or the bore is too much and the rod had play. When I run it on high speed it vibrates the hell out of everything. I can even feel it on my feet through the slab it’s bolted to.
I have a new fed rod but don’t see the point in installing it into a sloppy hole so was wondering if anyone had thought about or gone through with adding a bearing? It would greatly reduce wear for sure and should be be easy finding a bearing because the shaft is 19.95 mm so a 20 mm bearing should work?
