[4]
Filling holes in table
[3]
[10] Like what you see?
32chevy
Newbie
Jan 27, 2017
13
My fathers delta drill press spent its life in a high school metal shop, its full of holes through the table. Has anyone had experience in filled their table? Is it's possible succesfully weld the holes and surface grind the table?
ACHiPo
H-M Supporter - Gold Member
Feb 2, 2017
643
Why do you want to fill the holes? Can you still clamp work to the surface?
32chevy
Newbie
Jan 27, 2017
13
I'll have to post pictures and get get your opinion. It looks bad.
markba633csi
Gold
Apr 30, 2015
3,986
I'd recommend a cold repair with epoxy, maybe with metal plugs, no chance of warpage that way.
Mark S.
ewkearns
Active Member
Jan 6, 2017
86
I've always wondered if tapered, threaded, ductile iron plugs (like used in engine block repair) wouldn't make the blemishes disappear.... Irontite™ is one of the brands.
hermetic
May 2, 2011
528
If it has no T slots, you can bolt a peice of 1/4 or 3/8 plate to the table with countersunk fixings and flycut it from the spindle. Seen this done several times, and it leaves an undetectable repair, unless you look underneath. Fit the countersunk screws to the plate, weld over the heads, gind off flush, then flycut from the spindle to finish . You can do it with T slots, but more complex.
Silverbullet
Gold
May 4, 2015
3,454
Devcon makes some metal epoxies that look like and have metal in them. Hard to beat for repairs like that. They list several kinds of metal , even real expensive metals. I've got some to do mine but haven't been able to get them done. Couple vises and drill presses I'm going to do.
rrjohnso2000
Sep 19, 2014
230
I've used the devcon metal epoxy. It does a great job of filling the holes and is very easy to do. In some things it's tough to see the patch, others they stick out. For me filled has always been the priority.
tq60
Brass
Jan 11, 2014
753
Mix in grinder dust which is the pile of steel inside the bench grinder covers.
Wash out the abrasives then with magnet collet ferrous stuff then clean with acetone and mix into epoxy to make steel putty.
Grandpop
H-M Supporter - Silver Member
Jan 20, 2016
81
I do not like any holes in my drill press tables, so I buy a 3/8 thick steel plate and bolt it down with flat head screws. I make my plates bigger than the standard tables, make them rectangular. That provides lots of room for the 5"drill press vise or parallels I use, and provides for easy clamping with external clamps when needed.
[5] [7]
