I have a 5lb ABC mounted by the door, there is a second ABC and a 2-1/2 gallon pressurized "water can" that will be mounted on my welding cart when it is done. I do all welding outside the shop, so I like the extinguishers to follow the welder.
I have a basement shop so I added a smoke detector in a location under the living room / dining room with the hope that it might be heard up stairs.
Since there is only one exit from the shop I'm thinking about mounting a second extinguisher near the back just in case, and now that they have "smart detectors" I'm looking at adding another smoke detector that will send an alarm to my phone.
I try to be really good about shop housekeeping, at least in regards to combustibles / flammables storage and disposal. When I'm doing something that could potentially leave hot stuff hidden away, I make a point to hang out for a bit in the shop to hopefully catch anything that got where it shouldn't have got. I covered over the crummy (and more combustible) particle board wall covering with 5/8 sheet rock. Not only more appealing to look at, but also more fire resistant. Flammable liquids cabinets are very expensive, so I haven't done that, but I do keep them stored in in one area where they don't get exposed to potential ignition sources and it would be obvious if they were leaking.
In addition to the fire extinguishers there is the fire engine in the driveway... what doesn't everyone keep a fire engine by their shop?
As a retired firefighter, a fire would not only be devastating, but also professionally embarrassing.
Fire prevention is more important then fire suppression,
Absolutely, and it is a boring chore that seems an utter waste of time and money when it works (and no fires occur).
