Fireplace booboo
Stonebriar
Rick
H-M Platinum Supporter
Sep 2, 2013
378
My wife somehow knocked this off. Is there anything I can do to fix it besides knocking out the mortar and re mortaring?
Thanks
Rick
Thickened epoxy would probably work just fine. If you apply it carefully with no squeeze out it might not even show. JB Weld would be a suitable product. What you'll need to do is find a
way to "clamp" it with some pressure until it cures, but that shouldn't be too hard.
CLEAN and DRY are your friends...
And be sure to apply pressure until it cures (hours, or overnight)
Then choose a strong bonding adhesive or cement (not mortar)... and you should be fine
I veneered a fire box for down at the dock in that stuff. PL Premium Construction adhesive and you are good to go. Use gloves and you will need something to support it in position for 12 hours (overkill). After it cures it will be the strongest surface in the house, lol.
Gorilla Glue is your friend in that situation.
Double back tape would hold too . The car mounting type once stuck its stuck. So STICK IT AND FORGET IT .lol
The construction stuff is best.
If you can get double stick tape to stick then small amount can be used to hold until cured.
construction adhesive and gorilla tape to hold it till cured
