First Chips! PM-25MV
codexmas
Sep 11, 2019
22
It's been interesting to say the least after receiving my machine on Sep 23 last week.
Having very limited access to my basement shop I opted to pickup the machine at the truck depot.
This saved a bit of money not having the lift gate service, and gave me the option to deal with weather as I needed to disassemble it.
I would not have been a happy camper with a crate outside my place in a torrential Portland downpour.
Disassembly was mostly straight forward, not much actual information out there on it really, specifics I mean.
Several of you provided some helpful info in other threads so thanks again for that!
The main issue I encountered is partly being so new to "real" milling machines, a general lack of working knowledge.
Separating the X table from the base just wasn't happening. Turns out all that was needed is for the gib to be slid out and it comes right off.
I had been in the depot for well over an hour and it was getting dark, so I humped the base and the X table in one piece into the car.
Cleaning and proper dismantling in the shop was a lot of fun, really getting to know the machine. Quite a lot of elegant simplicity really.
I can see that I want a one-shot oiler mod soon, some of those little valves are tucked away!
As luck would have it I scored a really solid machine table on Craigslist to mount it on, very happy with the setup, no compromises.
Nice 1/4" welded steel, it took some care to hand drill the holes in it with my pedestrian drill.
So last night I finished getting it setup to the point of making the first chips. Got a bit too excited and forgot to put the chip guards over the lead screws...
Cleaning that up carefully is the plan for tonight as well as removing that pain in the ass front chip guard.
One thing I noticed that is rather annoying is the slop in the X table hand wheels. It seems like it is the play between the wheel and it's key in the shaft?
I'm considering ways to reduce that, curious if anyone else has noticed or cares about the 'knocking' noise it makes.
I'm currently planning on replacing all of the gib lock levers, simply annoying and low on ergonomics.
Too easy to leave them in a collision path, several times already actually.
Likely just 8mm bolts with knobs that I machine.
Power feed is also high on my list, especially after performing the first few operations. Good to have the feel of things for a while, until it aches more than you learn right?
Might do a DIY version to give myself a high value project to complete quickly.
I did record my first chips for posterity and laughs, some basic editing and it is almost watchable!
Happy to be a part of the community, hope to learn from others here and help where I can!
Support from PM has been nothing but stellar, even when my questions are noobtastic :)
Your killing me here, lol.
I look forward to more from you.
I had planned on a mill from PM late spring or mid summer. Well that didn’t happen just to much going on at work.
My plan is now next year.
Don't worry too much about that. A little bit of aluminum on the leadscrews isn't going to kill them. Even well covered, chips make their way in and make a mess under there. They can survive it.
I have a theory about that front chip guard. I am thinking it is specifically designed to get in the way when milling, and they know it will be removed. This way if someone hurts themselves using the machine and try to sue, they can argue that people removed safety equipment and they can't be held liable anymore. I don't think I have ever seen a machine with those guards left on them.
That seems unlikely to me. On my machine, the fit between the keys and the keyways were very tight. If they are a sloppy fit, it should be immediately clear, and that is a defect that PM can probably sort out for you. I would look at other sources first. Make sure the nut is secured tightly to the saddle, the gib is well secured, and the leadscrew is snugged up well with the endcap bearings. You shouldn't have any knocking when rotating the handwheels.
The leadnuts also have backlash adjustment, you could try increasing the tension on those if all else fails.
Congrats on the new machine! I have spent many hours making things with mine and I hope you find yours just as useful to you.
Congratulations, exciting times indeed.
Nice video.
-brino
Congratulations on your new mill. I've had mine for less than a year and enjoy it very much. You'll love the DRO. YouTube is a great learning resource for us beginners.
I've done a couple things to make the mill easier to use, so you might want to think about these.
1. Power feed the Z-axis.
2. New locks for all three axis. Y-axis locks simultaneously with a tug on a lever setup, X-axis has knobs now, as does the Z-axis. These make it easier to lock each axis and does a better job than the supplied lever type locks.
3. Fine down feed screen is not back lit and dependent upon your lighting it can be hard to see. I removed the chip screen, cut off the metal rod and mounted a small arm to which I attached "button lights". My wife gave me the lights from her stash that she uses for making miniature things. It lights up the screen very well and when it dies, just throw it away and put on another one.
I can add pictures if you like.
The guys on this site are great and very helpful. Don't be shy about asking questions.
Denny
Cool, going to give it a good looking over tonight. Cleaned all the mess up yesterday.
All in due time, I spent at least six months heming and hawing before finally making the decision. No regrets, though I do think I am a bit crazy, this machine while the smallest they sell is substantial! Taking a lot off to chew for sure, but as it becomes more familiar I feel less overwhelmed.
Denny
Very cool, I'm definitely glad I opted for the DRO and not a DIY path. Benefits to both, I could have handled the install for sure, but getting started with it in place means I can spend more time making things and less tweaking the machine. Lots of other tweaks to do on it in any case.
I am very curious about your mods and would highly appreciate any info. Especially the locking changes and the Z power feed.
I did my own ugly hack power Z feed on my PM-30.
For completeness, there is a PM-25 pre-made Z feed available, of which I have no direct knowledge:
I purchased the X power feed from PM, but I expect that at some point I'll get annoyed enough to replace it with something of my own design, probably stepper-driven or servo-driven so that I can set actual travel rates instead of winging it as I do now with an unlabelled potentiometer. If you have inclination and expertise to do your own and feel like sharing your design here I wouldn't be surprised if others were grateful. ☺
