- Mar 5, 2023
- 65
In my opinion a 3" grinder would be nearly useless for tool bit grinding, If I were looking for a grinder for tool bits, it would need to be with at least 6" wheels and definitely not from HF, due to excessive vibration from their grinders. even with new USA wheels, they still shake.What you have is a HSS cutting blank. It's not meant to be used without grinding. It should be sharp enough to cut YOU if you want it to cut metal.
You are going to need to learn how to grind a cut if you are going to own a lathe. If you don't have a grinder, get one with a coarse wheel and a fine one.
Also, when you grind a bit you want to never get it too hot. Grind and dip works well for me.
Use the coarse side of the grinder to rough out a shape and the fine side for a finish pass.
A cheap grinder with a good final pass wheel is the one from Harbor Freight.
Harbor Freight Tools – Quality Tools at Discount Prices Since 1977
Harbor Freight buys their top quality tools from the same factories that supply our competitors. We cut out the middleman and pass the savings to you!www.harborfreight.com
The wire wheel side won't last long but the grinder side is durable enough for fine grinding bits.
The one I showed is ONLY for a fine finish grind (or resharpening). I never had faith in one of those either until I tried one. It's balanced enough to spin the 3" wheel at 10,000 RPM which is close to where I used it for sharpening bits.In my opinion a 3" grinder would be nearly useless for tool bit grinding, If I were looking for a grinder for tool bits, it would need to be with at least 6" wheels and definitely not from HF, due to excessive vibration from their grinders. even with new USA wheels, they still shake.
The one that I am referring to was a 10", it was given to me, it shook so much that I bought the USA wheels, made new flanges and washers, and it still shook so bad that it is useless for most any grinding, add to that, the guards are tinny and the toolrests are so thin, and flexible that they are unusable, it sits under the bench, I will likely take the wheels off and toss the rest.The one I showed is ONLY for a fine finish grind (or resharpening). I never had faith in one of those either until I tried one. It's balanced enough to spin the 3" wheel at 10,000 RPM which is close to where I used it for sharpening bits.
Odd. That rounded edge made me think they were identical to the blanks I bought. Only my blanks had a sharper edge.These 2 bits are not blanks, they have been ground. I had a very well known member here make these for me so that I can get my feet wet before jumping in the whole "shaping of tools" pool. For me, baby steps is more manageable. I know that I'll need to make HSS tools, but these are literally my very first cuts, ever. So, one thing at a time.
The wheels are probably why it shakes. A different set of wheels might go a long way but the ones on it are likely junk.The one that I am referring to was a 10", it was given to me, it shook so much that I bought the USA wheels, made new flanges and washers, and it still shook so bad that it is useless for most any grinding, add to that, the guards are tinny and the toolrests are so thin, and flexible that they are unusable, it sits under the bench, I will likely take the wheels off and toss the rest.
