Thanks. I think I'll just go with the stock single phase machine with pulleys. When/if the motor dies I can contemplate a 3-phase with VFD.
I'm inclined to get the DRO and X feed installed, but we'll see.
The power feed (PF) for the X-axis is easily installed, if you want to save a few bucks or just want to do it yourself. It is definitely worth having though, as it makes long(er) cuts along the X-axis so much easier (and better looking). If Matt will install the DRO for you, it would save a few headaches. And, if anything goes wrong it's on him.
If the head is like mine, changing speeds is not a big deal really. While I mostly leave mine in the middle of the range and use the speed pot on the VFD, it only takes a few seconds to loosen the motor, pivot it slightly, and slip the belt onto a different ratio. Because I very seldom do it, I have a harder time remembering how to change from hi to low range.
Of course you will be required to post copious amounts of pics if you buy this new mill...
